Oil mixing question.....
Old Dec 17, 2007 | 05:05 PM
big b 's Avatar
Default Oil mixing question.....
I have a 1995 Scrambler 400 2 stroke.... I have never had a 2 stoke before... Do I need to mix the oil myself or does this have a oil pump ? I never have even looked at it enough to see ... I just bought it and it is time to put some gas in it ....
Thanks
Old Dec 17, 2007 | 06:11 PM
ftwflh's Avatar
It has an injection system if it hasnt been done away with.You fill it in the front nose piece
Old Dec 17, 2007 | 07:16 PM
ohnet's Avatar
I also have a 95. I have the tank (in the hood), but it was disconnected prior to my ownership. You might want to ask the previous owner how it's set up. Currently I'm mixing 40:1, but a lot of people like to run them at 32:1 if you premix.
Old Dec 18, 2007 | 08:36 AM
big b 's Avatar
There is no tank under the "hood" or plastic center nose piece. They have a round thick sticker carbon graphite looking thing over the round hole. The only tank I see is on the side and I believe that is the over flow for the radiator...
I have a few more quick questions ... What is the normal and max coolant/engine temps I should run it at? I bought a Trail Tech computer and it shows the temp. Right now being around 20 degrees outside it will idle at around 155 F and run at about 140F Is this ok?
Also what is the easiest way to measure for pre-mixing?
Thanks
Old Dec 18, 2007 | 09:25 AM
deanz400's Avatar
just buy a quart and it usually has a measuring window on the side of it
Old Dec 18, 2007 | 07:12 PM
ftwflh's Avatar
On the oil you need a RatioRite mixing cup and you need to run 40:1 mix
Old Dec 20, 2007 | 10:45 AM
badazz400's Avatar
140-155 is a great temparture!
on gas i have seen mine creep up to 185-190.
im on alky now and i never go over 140
exmotocrosser
Sep 13, 2019 06:12 AM
nachop
Feb 14, 2018 06:57 PM
Shainasmash
May 8, 2017 06:38 PM
greg74
Sep 10, 2015 07:58 AM
bpegram84
Jul 22, 2015 08:15 AM
