Front Strut Removal
Old Dec 9, 2007 | 11:16 AM
Yankee02's Avatar
Default Front Strut Removal
I am trying to remove the front strut to replace my boot. I have the bottom unbolted but I am trying to remove the front strut to replace my boot. I have the bottom unbolted but can't get it out of the A-arm. Any ideas or what am I missing?
Old Dec 9, 2007 | 11:39 AM
onesavage's Avatar
are you talking about the ball joint..if so you can buy a balljoint/tie-rod seperator and ANY auto store..i just yake 2 hammers and smack both sides of the a-armbut the ball-joint at the same time and it is that easy..
Old Dec 9, 2007 | 01:22 PM
Yankee02's Avatar
Here is what I am trying to seperate. I went and got a Tie rod tool and so far no luck. I did not want really hammer on it until I know there is nothing else holding it.
Old Dec 9, 2007 | 03:23 PM
onesavage's Avatar
put a hammer on the a-arm at the bottom where the balljoint goes through and then whack the other side with another hammer..works every time for me..
Old Dec 9, 2007 | 03:26 PM
Kerbbirds's Avatar
I use a big punch at the top of a-arm where it meets the ball joint, one good hit with a big hammer and it will come apart.
Kerbbirds's Avatar
Old Dec 9, 2007 | 04:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
jim, its like a car its on a taper and hitting sometimes will get it off or i would use a seperator to get it off but you dont to take the strut off completely to get the shaft out of it. just pull it out a little. did you get it all straighten out? i forgot the question you sne tme sorry been wicked busy on my sled.
Old Dec 9, 2007 | 09:02 PM
BikKat's Avatar
Never mind . . .
Old Dec 9, 2007 | 11:02 PM
ftwflh's Avatar
A tie rod tool works best.But you can womp thye sides with a hammer then tap down on the A arm and it usually drops right off
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
