need help
Old Dec 11, 2007 | 11:53 PM
kennedy1011's Avatar
Default need help
I have a 1995 sportsman 400 that wont stay running while at idle. It almost feels that it is running out fuel. I changed the fuel filter and took the carburator apart and cleaned it. I dont know what else to do. Any help or comments will be great.
Old Dec 12, 2007 | 12:12 AM
sjbr549's Avatar
Default need help
floats could be sticking or trash in the tank or the valve has got trash in it
Old Dec 12, 2007 | 12:28 AM
Kerbmonster's Avatar
Default need help
check your throttle cable play, if it's too loose then your etc kicks in and it won't idle, but itll run good everywhere else
Old Dec 12, 2007 | 07:28 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default need help
if by pulling the choke out helps it to keep running then its a lack of fuel problem for sure.
Old Dec 12, 2007 | 08:14 AM
ftwflh's Avatar
Default need help
check the vent line for pinch or stopped up
Old Dec 12, 2007 | 09:42 AM
94harley's Avatar
Default need help
Could be a vacuum leak as well. Spray carb cleaner around the carb boot, cylinder gasket etc. If the idle speed changes. Vacuum leak.
Old Dec 12, 2007 | 01:14 PM
sjbr549's Avatar
Default need help
could be just old gas mine wont run if the gas is in the tank for a week maybe two. it spits,sputters and dies
Old Dec 12, 2007 | 03:44 PM
Mongrol's Avatar
"Official Site Skeptic"
Default need help
Check Kerbmonsters solution, the ETC, electronic throttle control, is probably out of adjuctment and is easy and costs nothing to fix.
