2004 Sportsman 700 EFI
I have a problem with my 700 not starting sometimes. It will turn over but not fire. I will change the plugs and it sometimes will start but not always. When I run the code i get injector codes. Any help in the right direction would be great..
The codes it showed had to do with the injectors. I think it was 51. I talked to a local dealer and he said that the champion plugs are junk and i need to put in NGKs. I got some 7s but he said 6s or 5s. Thats all i got as of now. He also said that it could have to do with the battery.
When you turn the key on make sure you can hear the fuel pump pushing fuel for that breif second. I know when my battery was low it would not start make sure it is fully charge then give it a try. pull plugs if no start and make sure you got spark. some good starting points
hope this helps
hope this helps
well got new battery in and it seems to start fine now. now it justs backfires horribly. local guy told me to try NGK plugs. I got some BK7's. any recomendations from anyone else?
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 9, 2015 01:49 PM
