Oil Change 500 EFI
Old 12-28-2007, 01:36 PM
rick480's Avatar
Default Oil Change 500 EFI
Sheepdog. I have the same wrench, from a old Honda also. but I have no access to the back of the tank on my X2 like you are showing. I think the only solution is to remove the tank.
Old 12-28-2007, 02:18 PM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: rick480
Yes, it is a X2</end quote></div>
Clean the screen with the 1st oil change to get any break in material off it and then maybe every yr after. You don't need to clean it after every oil change. Well unless you swamp in in mud! The oil filter will remove any small particles.
Old 12-29-2007, 09:51 AM
onesavage's Avatar
man ,just because you dont want to spend the extra 1/2 hr to remove the tank and clean the screen sure hope not to see you kicking your tire on the trail cause of a lack of oil flow... its easy to do ,i do it every time the 400 and 500 have the same tank its not that bad ..to each is there own
Old 12-29-2007, 10:00 AM
The Black Pearl's Avatar
For the X2 does the oil tank have to come off? Yep looks like it does. Now how? There is no way to get to the screen from what I can see without removing the oil tank. HEEEEELLLLLPPPPP
  #15
Old 12-29-2007, 04:24 PM
onesavage's Avatar
on my 400 all you do is take out the 2- 10mm screws and disconnect the hoses..never takes more that a 1/2hr to do and when i have the tank off i always flush it with kerosene or gas than let it drip dry..just good to do!! in my eyes undisputeable
  #16
Old 12-30-2007, 10:14 AM
brutus450's Avatar
i found getting the hoses off was the hardest part of the whole job, what a pain in the azz they were - maybe because it was the first time. hope they come off easier next time!
ReconBayou
10-31-2022 05:37 PM
ultangler
09-05-2021 08:06 PM
Jackg17
Ask the Editor
07-16-2018 04:01 AM
Gwolf228
02-18-2017 01:36 AM
Jackg17
09-26-2015 09:30 PM
Quick Reply: Oil Change 500 EFI
