lookin 4 plastic, motor, and other stuff 96 trail blazer ALSO wont start!
Old Jan 1, 2008 | 10:56 PM
doctor_boost's Avatar
Default lookin 4 plastic, motor, and other stuff 96 trail blazer ALSO wont start!
HI, i need some plastic for my 96 trailblazer. the other owner thought it would be cool to spray paint it...... ya Real cool!
My motor wont start. this was a ebay deal. they said it needed the carb rebuilt.
I changed the plug, and its getting fire. It wont even hit. I dont thank its sucking gas in to the motor. i dont know if its the compression or what?
anyways if u have some parts. hit me up.
doctorboost@hotmail.com
Old Jan 2, 2008 | 07:03 PM
No one have nothing hugh......?
Any one know why ist not starting?
Old Jan 2, 2008 | 10:50 PM
ohnet's Avatar
I've been looking for plastic also. I found 2 trail blazer plastics on EBAY. You might want to look into one of those. Search EBAY MOTORS, and put in "Trailblazer fender". That should do it...... or "POLARIS FENDER".
Old Jan 2, 2008 | 10:52 PM
eggenz7's Avatar
are you sure your getting gas to the carb? maybe it needs a carb rebuild because its been sitting and the gas has gummed up over time causing all those little passages to become blocked.
thankx bro.
Old Jan 2, 2008 | 10:59 PM
<div class="FTQUOTE"><begin quote>Originally posted by: eggenz7
are you sure your getting gas to the carb? maybe it needs a carb rebuild because its been sitting and the gas has gummed up over time causing all those little passages to become blocked.</end quote></div>
I thank it is. The carb was just rebuil and cleaned good. I can get it started with starting fluid and it will run....ok very doggy. Ii ran a compression test on it and it only about 90-95 the more i pull the more it goes up. till about 100.
I got it started and it wont idle very well at all. It also has a bad tranny i thank.
I kept hearing a grounding sound when i get on the gas and i thought it was just the chain/ sprockets, Nope there new. and tight.
I checked the oil and thers matle shavings in it. Time for a tranny also. i thank.
jace
Sep 10, 2020 08:30 PM
1000gade
May 27, 2015 12:37 PM
covert
Apr 29, 2000 09:54 PM
97TrailBlazer
Dec 6, 1999 10:33 PM
Rod
Oct 4, 1999 12:37 PM
