350L counter balance question
Old Jan 2, 2008 | 08:52 PM
isinkdk's Avatar
Default 350L counter balance question
I just bought my son an old 350L and there is water in the counter balance oil. My manual has a picture pointing to nothing where the cb drain plug should be. This is between the tranny plug and start pull drain plug. Does anyone know how to drain the cb oil. Thanks in advance
Old Jan 2, 2008 | 10:31 PM
ftwflh's Avatar
It is a 10mm bolt on the bottom of the crankcase.There is 2 one is the crankcse drain the othere is the counterbalance
Old Jan 2, 2008 | 10:36 PM
isinkdk's Avatar
Thanks for the reply but mine only has the one. Is it under the starter by any chance?
Old Jan 2, 2008 | 10:38 PM
ftwflh's Avatar
It should be behind the case witht he pull starter
Old Jan 2, 2008 | 10:48 PM
ohnet's Avatar
I posted a picture on my gallery of how it looked when I pulled the skid plate off my scrambler. It's probably not identical, but I bet it's real similar to yours. Take a look, I hope this helps.
Old Jan 2, 2008 | 11:50 PM
isinkdk's Avatar
thanks guys, I pulled the skid plate and there it was. Now comes the hard part figuring out where the water came from
Old Jan 3, 2008 | 07:54 AM
ftwflh's Avatar
the water pump seal or from being sunk in water
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
