Chain loose?
Old Jan 10, 2008 | 10:45 PM
chevyman2454's Avatar
Default Chain loose?
Hey guys! I was doing a general inspection of my 04 Trailblazer 250. I noticed my chain felt a little loose??? I have never paid attention to it before but before I go riding I always spray the chain... Is there any way to check if my chain is loose or if its just me??? All answers appreciated.
Old Jan 10, 2008 | 11:30 PM
crashnrole's Avatar
this is from my 400 manual but may help, chain is adj right when it has 3/8 deflection. put it in gear and get the top part of the chain tight, you should then be able to move the top part of the chain 3/8", to adjust,I loosen the 2 eccentric clamp bolts and the bolts on the rear caliper and turn the cam in the mid rear axle to tighten/ loosen. again this is for my 400 if i'm wrong somebody correct let me know if you need pics and I will scan
Old Jan 10, 2008 | 11:35 PM
crashnrole's Avatar
just for info I think I have been doing more harm than good w/ chain oiling. will try this chain w/ nothing but dry silicone lube spray. think the oil based spray I was useing was just a dirt magnet
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
bmark0610
Sep 7, 2015 09:42 PM
