Battery problem
Old Jan 12, 2008 | 03:07 PM
LT904's Avatar
Default Battery problem
Please help an idiot!! I tried charging the battery on a POLARIS 450 while the battery was still connected to the machine. I think some kind of fan started running When the machine wouldn't start, I took out battery, charged it and put back in machine. The fan started running immediately with out ignition turned on. Dash then shows running hot once the machine is started. Since this toy isn't mine did I screw something up?? HELP
Old Jan 12, 2008 | 05:55 PM
twister500's Avatar
Sounds like a bad thermostat switch or sending unit thati s in the radiator. It is keeping the fan running all of the time. Forget it just saw the ing. off part.
Old Jan 13, 2008 | 08:35 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if this is an 06' sportsman 450 then chances are the emc is bad and needs replacing as they did have a problem w/ some of them. if its that, then maybe its one of the ones that falls under the recall list. let us know.
Old Jan 15, 2008 | 12:59 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
BAD ECM!!..........I replaced two in my 2006 Sp 450.......Let us know ..........Thanks......Caper..........
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
