ATV Security locks and chains
Old Feb 20, 2008 | 12:56 PM
Y-Guy's Avatar
Default ATV Security locks and chains
What insurance company are you using? Between my home owners and my ATV insuranec with Progressive I'm covered and never been told to lock it up.
I do lock mine but use a combination of things. At home I run a heavy duty cable and contractor grade lock through them. While camping I use that, and an Alarm called a LockAlarm which will sound off a 129db alarm if its broken or the cable is cut. Then I cover them and have used small bells to make noise if they are moved.
Old Feb 20, 2008 | 01:56 PM
deanz400's Avatar
I cable mine together when I'm out camping and usually have one faceing either way ,to make it more difficult ,or to the trailer ,or pad lock thru the rear rotor
Old Feb 21, 2008 | 08:40 PM
opsman56a's Avatar
I use plastic coated Krytonite cable and railroad locks on the trail.
Home protection...I also have a wireless motion sensor on the atv and is powered by the atv battery. If the sensor is triggered, my Infared Red webcam records the motion in the garage. I can see whats going on from any pc. It also emails me via blackberry. Its backup is a Baretta 40ACP
Old Feb 21, 2008 | 09:01 PM
oliver454's Avatar
Thank you for all the different ideas. I just ordered a Kryptonite stronghold anchor to go into the cement in my shed and an OnGuard Beast cable to hold it there.
Old Feb 21, 2008 | 09:08 PM
  #15
wildwest1011's Avatar
I also use the krpytonite cable, looped through my wifes bruin, my grizzly, my lawn mower, ramps, plow and top frame of my shed.
All locked with a discus style lock. And I of course lock the shed.
Old Feb 23, 2008 | 06:19 PM
  #16
TxMagnum's Avatar
i take a front and rear tire on opposite sides off mine and put it on blocks in addition to chaining it to a post in my carport its not really that much trouble compared to having your rig stolen. i keep the tires locked in a closet in the house. also leave some empty shell casings lying around especially near a red paint stain. sounds crazy but nobody messes with my ride when i am gone to work for a couple of days.
Old Mar 2, 2008 | 01:20 PM
  #17
oliver454's Avatar
I received my Onguard Beast Chain & Lock yesterday and you should see it. The chain has 12mm titanium links and the lock is a Beast and you get 5 keys. Here is the website.
www.onguardlock.com
mrtidy
Feb 3, 2016 05:00 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
