250 trail blazer
Old Feb 25, 2008 | 11:22 AM
Blacksheep5's Avatar
Default 250 trail blazer
yep thats how it works until the oil pump fails and the motor burns up.
Old Feb 25, 2008 | 12:12 PM
itch's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Blacksheep5
yep thats how it works until the oil pump fails and the motor burns up.</end quote></div>
don't let this worry ya it hardly ever happens, polaris oil injection in a good working system and i've never had one go out and burn up the motor and i bought my first polaris in 1991 and have had several since, just check the cable and spring occasionally and adjust as needed
Old Feb 25, 2008 | 08:14 PM
ohnet's Avatar
Yes, I agree. Looks like a good purchase. Have fun!
Old Feb 25, 2008 | 09:31 PM
zz8t's Avatar
i read that it has a pvt drive is this similar to cvt?
Old Feb 25, 2008 | 09:44 PM
  #15
700 sportsman's Avatar
I think that its a pretty good deal too
Old Feb 26, 2008 | 01:50 PM
  #16
spb_8980's Avatar
if you have no warrentee i would switch to pre-mix,my oil pump failed and it was $1,200 to fix,from bottom end to crank case, piston,bearings.... why chance it?
Old Feb 26, 2008 | 02:12 PM
  #17
here is what the kit looks like
Oil Injection Block Off Kits
Eliminate the possibility of an engine seizure due to an oil pump failure. Kit includes the plug and plate needed to remove the pump. The oil tank can also be removed when pre-mixing the fuel.
http://www.hotseatperformance....duct_ID=2891&CATID=248
Old Feb 26, 2008 | 04:15 PM
  #18
zz8t's Avatar
what if i just mix the gas and dont get the block off kit?
Old Feb 26, 2008 | 05:17 PM
  #19
I have no idea, but better safe than sorry for $24.95
Old Feb 26, 2008 | 07:02 PM
  #20
ftwflh's Avatar
Injector failures are very rare and most times it is due to a bad cable.
