Sportsman front suspension question
Old Feb 29, 2008 | 02:50 PM
jsa's Avatar
jsa
Default Sportsman front suspension question
What is the deal with the angle of the front wheels on the Sportsmans? You know, the way the angle in at the top. Is it due to the use of struts or something?
Old Feb 29, 2008 | 03:01 PM
Blacksheep5's Avatar
the springs start to sag from the added weight of stuff, winches, plows, gear, etc
check out www.erlandsonperformance.com for heavy duty springs
Old Feb 29, 2008 | 03:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
or add spacers to take some of the slack up. either way would help straighten the fron end back up. sportsmans have weak front springs w/ no adjustments.
Old Feb 29, 2008 | 03:38 PM
whiplash450's Avatar
I made a set of 3/4" spring spacers outta couple two piece set collars and that staightened it right out
Old Feb 29, 2008 | 04:46 PM
deanz400's Avatar
I made a 1" spacer mainly for the plow on my trail boss
Old Feb 29, 2008 | 05:17 PM
Brainerdian's Avatar
Careful if you have a plow on the front. If you raise the front end (at least with the Glacier II system) it will change the height of the mounting bar.
If the mounting bar is raised and the plow is angled to one side then the trailing edge of the plow will be off the ground by the amount that you raised the mounting bar. (The leading edge will dig in and the trailing edge will leave snow on the ground.)
Also if you put more than 4 psi in the front tires the same thing will happen.
I don't think you'd have the same problem with other plow mounts because they usually mount back farther.
I put the yellow Highlifter HD springs on and it didn't raise the mounting bar height more than 1/4" but it did stiffen up the suspension nicely.
Old Feb 29, 2008 | 08:47 PM
Mikka's Avatar
Polaris line of equipement Pure is now selling after market spring load adjusters for the front end springs. Anybody gave them a try yet? would it negate the need to install heavyduty spring?
http://www.purepolaris.com/Det...463(PolarisPGACatalog)
Mphillips
Jul 29, 2015 08:53 PM
yellowpolaris
Jun 21, 2015 11:13 AM
CountryMiles
Oct 25, 2000 01:03 AM
ogre
Jun 7, 2000 08:35 PM
