One spark
Old Mar 5, 2008 | 10:45 AM
the bayou's Avatar
Default One spark
Since things have changed I have decided to make a new thread..............on my 1992 polaris 350L 2 stroke if I try to start it(Pull start only) Ican pull it several times and get one solid blue hot spark every 4-5 pulls........What does this mean? this would mean the stator is good correct? Could it be the coil? I just replaced the wire and the cap. What all could cause this?
Old Mar 5, 2008 | 12:49 PM
the bayou's Avatar
Default One spark
anyone???
Old Mar 5, 2008 | 02:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default One spark
could mean differnt things. coil could be getting bad. could have rust built up on the flywheel and not making good contact when its turned over. ou've tried a difernt plug im assuming.
Old Mar 5, 2008 | 02:36 PM
the bayou's Avatar
Default One spark
man stendori you are everywhere! well first off just wanted to make suyre I was right by starting a new thread!?since it is a new issue. Also, this rules out the staor doesn't it? I have a coil on the way! any other suggestions?
Old Mar 5, 2008 | 04:35 PM
the bayou's Avatar
Default One spark
Is there anyother thoughts as to what it sould be i amreally trying to rule out the stator
Old Mar 5, 2008 | 05:36 PM
sprinter10's Avatar
Default One spark
the stator should be fine but as sendori said maby some rust on the flywheel that keeps it from getting good contact. maby there is a bad gound somewere. did you check te ground on the coil? are the nuts tight? no rust or anything like that.
Old Mar 5, 2008 | 05:44 PM
the bayou's Avatar
Default One spark
Yes I have even taken the coil off and put a new wire and plug cap on. when i did that i cleaned where the bolts go in. I will check for rust when i get to the shop Do I need to drain the oil to take off the side where the stator is?
Old Mar 5, 2008 | 06:09 PM
03scrambler500's Avatar
Default One spark
i had that problem on one once. It was a bad pick up coil also known as a trigger coil. Do a ohm check on it to verify it. The one I did was way out of spec. I almost thought there was something wrong with my meter. lol I put a new pick up coil in and the problem was solved. I'm not saying it might not be the ignition coil but test that pick up coil. Good luck
Old Mar 5, 2008 | 06:10 PM
the bayou's Avatar
Default One spark
where would the pickup coil be at on my 1992 polaris 350L 2 stroke 4x4?
Old Mar 5, 2008 | 06:22 PM
Default One spark
its under the recoil cover its on the stator plate. it looks like this
http://www.rickystator.com/cat...=24_38&products_id=328
BUT....I thouhgt you had a differnt type of ignition system I just looked at a microfich and noticed that your modle does not have that style. Sorry about that. Good luck. I would still Ohm check the stator though. It can tell you if its good or bad eaisly.
