hawkeye clutch roller mod
Old Mar 23, 2008 | 07:26 PM
TennesseeTider's Avatar
Default hawkeye clutch roller mod
yes it should
Old Mar 23, 2008 | 09:57 PM
Hawkman300's Avatar
how much would the cheapest impact wrench needed for this job cost, because i probably wont use it for anything else other than my atv.
Old Mar 23, 2008 | 10:54 PM
Rickeyparker's Avatar
Hawkman I posted a video of the clutch cover removal, by Popular demand ill leave it on Youtube.com heres the link
http://www.youtube.com/watch?v=o_IrT7qLNKo
Old Mar 23, 2008 | 11:18 PM
jokout's Avatar
It is VERY important to remember the red locktite on the threads of the clutch nut when you reassemble the clutch!
Old Mar 24, 2008 | 03:52 PM
  #15
DARETORIDE's Avatar
your supposed to use blue locktite...i have no idea what the difference is but that is what it said
Old Mar 24, 2008 | 06:33 PM
  #16
Hawkman300's Avatar
and the nut that you have to put blue loctite on is the big nut that you have to use the impact wrench on, right? thanks for the vids, i will probably do that this weekend and the airbox mod.
Old Mar 24, 2008 | 10:24 PM
  #17
jokout's Avatar
Dare, I would be a little skeptical of using Blue loctite since it is a light duty thread locker that is intended for bolts 1/4" to 3/4" with easy hand tool disassembly, we don't want this...Red (271) is intended for 3/8" to 1" threads and heavy duty use, we DO want this!
From Loctite's website:
OEM specified as 271
High temperature, high strength for heavy duty applications
Designed for larger fasteners 3/8" to 1" (9.5mm to 25mm)
Locks studs, bushings and large fasteners against vibration loosening
Strengthens slip and light press fits
Removable with heat and hand tools
Old Mar 25, 2008 | 07:30 AM
  #18
stendori's Avatar
Super Quad Patrol
I'm watching you!
most likely i would say use blue, as red is made more for threads you do want to come off again as it have alot more alot more staying power then blue. its basicly so the nut cant vibrate off. blue would be fine.
Old Mar 25, 2008 | 07:35 AM
  #19
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: Rickeyparker
http://www.youtube.com/watch?v=o_IrT7qLNKo</end quote></div>
good little video ricky, but you should have finshed taking off the clutch to give more intruction on the clutch removel. these videos these guys see are excellent help for people have never done this kind of work. keep up the good shooting.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 25, 2008 | 11:32 AM
  #20
Hawkman300's Avatar
he made different videos. im gona try that this weekend if i can borrow an impact wrench and my dad wants to talk to the polaris mechanic to see if its OK.
