Outlaw 525 + JDjetting Question?
Old Mar 13, 2008 | 11:30 PM
jimk72's Avatar
Default Outlaw 525 + JDjetting Question?
I just installed my JDjetting kit and the jet for the drain was optional. I was wondering how many that used this kit installed the drain jet? I was going to but didn't want to remove the extra parts to get to it if it doesn't make that big of difference in performance. I still have the tank removed so it would not be hard to open it back up and install it. Just thought I would ask before putting evrything back together.
Thanks in advanced for any help!
jimk
Old Mar 14, 2008 | 11:37 AM
CALDS650's Avatar
due you mean leak jet I went with the R&D power pump works better and is adjustable from the outside
Old Mar 14, 2008 | 01:35 PM
Evasiveone's Avatar
I tried the leak jet and absolutely hated the way it affected the bike. Made it almost unridable. Anytime you hit the throttle it would stall or flutter. So I went back to the stock plug jet with the big o-ring and adjusted the AP timing to .100".
Old Mar 14, 2008 | 05:11 PM
gablett's Avatar
I run the same as evasiveone. Some people have good luck with the leak jet, but most KTM's dont. My friend has an FCR 39 on a Z400 and his does way better with a leak jet. I think KTM's suck so much air they need that extra power in the Accel. pump spray. I would recommend setting the AP linkage to .100", seems to work good on these bikes.
Old Mar 14, 2008 | 06:01 PM
jimk72's Avatar
Thanks for the info I will leave it the way it is then. I didn't remember anyone else saying they used it but I just wanted to make sure [img]i/expressions/face-icon-small-smile.gif[/img]
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
