Hawkeye Rear Spring Adjustment.
#21
Im working on a fix for that very problem , but im also working on a bushing replacement spring for the Sway bar system on the hawkeye/sprtsman the rear is so narrow that if the either wheel moves up or down the the other wheel is meeting resistance at the same time, thus causing that stiff Suspension i figure if I give the sway bar an extra inch or 2 inches of movement before it starts ligfting the other wheel then it would soften up alot, Like sheepdog said though ive removed the sway bar and it rides super Smooth, but i had to up the preload on the shocks and it worked good , but i was Afraid i would break something and put it back on. Ill try to Post Some Pictures again " Wish me Luck" on Posting Pictures.
#23
#24
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
im afraid if i took the sway bar off that in corners it would tend to body roll too much causing it to be unstable in the hard corners on fast speed.</end quote></div>
Since that is the whole purpose of the sway bar that would be a good guess.[img]i/expressions/face-icon-small-wink.gif[/img]
#25
#26
with teh sway bar off i think you will be able to get moresuspention travel like a twist like when they do those tests were you drive up a ramp with one front wheel untill one of the tires come off the ground. so it might be better rock crawling but it will leen and won't handle as good in the corners and when you go to hop a tree and hit it on an angle it will lean ofer on one side. when you have the sway bar it stays a lil straiter like a scrambler when you hit a tree on an angle because of teh strait axle. thats what i think at least.
#27
#28
with at straight rear axle (single shock) both tires move together.. a little rougher ride. with the independent rear each rear tire will move by itself.. the movement is however limited by the sway bar.. (that is the metal bar that connects to each side)
check out youtube: search for "polaris hawkeye independent suspension" by vlastic this will show you how the suspension works.
