sportsman 600 making noise in reverse?
Old Apr 7, 2008 | 07:47 PM
clutchoo7's Avatar
Default sportsman 600 making noise in reverse?
im looking to buy a polaris 600 sportsman,it is a 2003 pretty much in good shape other than when in reverse a "clicking"noise is really noticeable,im not to familiar with polaris or the drivetrain,any suggestions would help..thanks guys for the help
Old Apr 7, 2008 | 08:05 PM
Taker's Avatar
my guess would be that its the back cv joint axle I have a 04 600 SP that I'm currently changing the back axle in because the CV joint went bad and started clicking. When it first started to go bad it only did it in reverse, but now its doing it in forward as well, it really makes a noise when I turn a tight circle to the left.People on here with more knowledge then myself will probably chime in soon.
Old Apr 7, 2008 | 08:51 PM
DODGE57HEMI's Avatar
Mopar Man!
Sportsmans use a u-joint drive train compard to cv-joint drive train found on other manufacturers. This is probobly the noise's you are hearing. If you are having troubles/ noises while turning it is probobly a bad u-joint. This is all due to slack in the drive train catching up w/ the speed of the motor while braking, going down hill and reverse it's considerd normal like it or not. Hope this helps!
old quads
Aug 13, 2015 10:32 AM
mpcop077
Jun 10, 2015 08:30 PM
Dylan.11
Utility ATVs
Jun 4, 2015 03:58 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
Fullblast
May 26, 2015 12:38 AM
