jet kit?
Old Apr 11, 2008 | 09:20 PM
master blaster's Avatar
Default jet kit?
I am new to this forum and was wondering if a k&n filter and jet kit would be worth doing? seems to have some throttle lag. also would it be wise to put a larger snorkle on? stock one seems very restricted. I would appreciate any help.
Old Apr 11, 2008 | 09:54 PM
firehog's Avatar
Default jet kit?
More air in + more air out = increased hp....so definitely worthwhile imo. Before you rejet pay close attention to where the throttle stumbles...idle to 1/8 throttle, mid, or full. This will indicate where you need to make your changes. Your on the right track, tho.
Old Apr 11, 2008 | 11:06 PM
matt1969's Avatar
Default jet kit?
mine stumbles just after idle.i put in a jet kit,what do i need to do.
Old Apr 11, 2008 | 11:46 PM
firehog's Avatar
Default jet kit?
Have you adjusted the pilot screw? Your problem is likely in the pilot circuit.
