ATF in the front hubs
Old Apr 19, 2008 | 01:13 AM
TxMagnum's Avatar
Default ATF in the front hubs
A local shop I'm starting to buy parts from told me today that I didnt have to buy the expensive oil for the front hubs and that automatic transmission fluid worked just as well. Does anyone else know, and if so should I use dexron, atf+4, jetaway or what. I use the high dollar mopar in my truck but that's cause it cost more than my house, I have a crappy house not an especially nice truck.
Old Apr 19, 2008 | 02:35 AM
Krammer220's Avatar
TYPE"F" transmission fluid is what Polaris recommends as an alternative to the demand drive fluid.
I've been using it, although I did just pick up a qt. of the Polaris demand drive fluid for $6.00... not too bad considering each hub only holds a few ounces.
Old Apr 19, 2008 | 04:38 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>A local shop I'm starting to buy parts from told me today that I didnt have to buy the expensive oil for the front hubs </end quote></div>
Exspensive? Its $12 at our dealer and the bottle will last for 7 or 8 changes.
I only change the hubs oil once or twice a year.
Old Apr 19, 2008 | 01:40 PM
jodaanja's Avatar
I have a 2000 Magnum 500. Great machine. I think it is a nicer ride than my '07 Sportsman 700 EFI. More controllable. Anyway, don't cut corners with the fluids to try to save a buck or two. Not worth it to me anyway. It doesn't make sense to try to get away with cheaper fluids, and risk voiding warranties or doing damage to my $7000 machine, just to save $20 bucks a year. EVERY fluid that goes into my two Polaris machines (other than gas) comes in a blue bottle that says "Polaris" on the side. PERIOD.
Old Apr 19, 2008 | 11:53 PM
Kerbbirds's Avatar
i would stick with the polaris oil, had transmission oil in front hubs one winter and the hubs didn't work very well, went to polaris oil, been fine since
Old Apr 20, 2008 | 12:05 AM
Jlutty444's Avatar
Hey- I am a newbie here. Just bought my first 4 wheeler. It's a 2000 Polaris Xplorer 400 4x4.
I cannot find a manual on this, the transmission fluid, or even if there is any crankcase oil in this beast. It has 800 miles on it.
Is there a procedure for changing the hub fluid somewhere on the web?
Old Apr 20, 2008 | 10:14 AM
TxMagnum's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
I only change the hubs oil once or twice a year.</end quote></div>
its a matter of perspective, compared to the other, the fluid is more expensive. but if it is not a good idea to put atf in there I will use the more expensive(relatively) fluid
Old Apr 20, 2008 | 11:23 AM
03scrambler500's Avatar
http://pi54.com/corp/manuals/Owners/9915471r01.pdf
theres a link to some specs. see if that helps. for the owners manual you could just get a service manual from your local dealership that would have everything you would ever need in it.
Old Apr 20, 2008 | 11:53 AM
Jlutty444's Avatar
Thank you. I did find that. Its a supplement to the 400 manual that was printed for the 300 (244cc engine spec).
Old Apr 20, 2008 | 12:08 PM
http://pi54.com/corp/manuals/Owners/9915472r02.pdf theres the right one
