need help with carb
Old May 8, 2008 | 08:05 PM
blknfury's Avatar
Default need help with carb
i have a polaris 325 magnum and recently had been getting gas in the crankcase oil area. someone told me it was probably the needle not set right. so i took apart the carb and i was trying to get the float bowl out by removing the long pin that hold it in place but it doesnt move what do i do?
Old May 8, 2008 | 09:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure what year the bike is, so i just took a peak at a 2002 and not sure what pin your talking about once you take the bowl off you should be able to see the float and if it has free movement.
Old May 8, 2008 | 09:31 PM
blknfury's Avatar
its a o1 but i know but i need to get the float off so i can get to the needle
Old May 8, 2008 | 10:36 PM
Kerbbirds's Avatar
You have to take a small punch and hammer and drive the float pin out a little ways, it is the needle and seat that is your problem, get a new one and change your oil, to prevent this from happening again turn the gas valve off when its parked for any length of time.
Old May 9, 2008 | 01:19 AM
blknfury's Avatar
i know what the needle is but what is the seat? and are sure u have to take a punch and hammer to it to get it out, because it seemed like it wasnt budging.
thanks,
Old May 9, 2008 | 01:42 AM
Rickeyparker's Avatar
The seat for the Float needle is what the float needle sits in to stop fuel flow, this is rarely the problem, probally just float height needs to be set.
Old May 9, 2008 | 03:08 AM
blknfury's Avatar
thanks, but i might as well just clean that area. the float pin (that holds the float bowl) wont budge seems like its not suppose to come off?
Old May 10, 2008 | 10:56 AM
blknfury's Avatar
while im workin with the carb does anyone know how to adjust the air fuel screw right? because last time i adjusted it by the manual and it was running on the rich side.
Old May 10, 2008 | 10:06 PM
blknfury's Avatar
anyone?
Old May 11, 2008 | 12:39 AM
Kerbbirds's Avatar
the float pin is kind of a booger to get out but it will come out, also if you have an spring loaded center punch, it will push it out for you, and the needle and seat goes out all the time, replace at least two a week at work.
