need help with carb
Old May 11, 2008 | 10:30 AM
blknfury's Avatar
Default need help with carb
thanks this helps alot, now how do i adjust the air/fuel screw?
Old May 11, 2008 | 11:10 AM
tstroker's Avatar
needle and seat, a common problem, i use small wire cutters, the type used for pcb assy. and repair, they are small enough to get behind the nail head on the float pivot pin, and it comes right out......stroker
Old May 11, 2008 | 11:14 AM
tstroker's Avatar
thats a fuel screw on your carb., anywhere from 11/2 and 3 turns out, depending on mods and size of pilot jet, also elevation......stroker<div class="FTQUOTE"><begin quote>Originally posted by: blknfury
thanks this helps alot, now how do i adjust the air/fuel screw?</end quote></div>
Old May 11, 2008 | 11:44 PM
blknfury's Avatar
hey thanks for the tip tsstroker, is there a way to adjust it while its on the atv? because i cant get no hand or tool in around there. and its stock so im guessing all the way in and then back it out 3 turns, right?
Old May 12, 2008 | 12:44 AM
  #15
Kerbbirds's Avatar
the only way u can do it is if the carb is upside down, and i wouldn't go 2 to 2 1/2 turns out
Old May 12, 2008 | 11:58 AM
  #16
blknfury's Avatar
so your saying to only back it out 2 turns? yea i cant have it upside down so what do i do?
Old May 13, 2008 | 01:48 PM
  #17
blknfury's Avatar
does anyone know how to tune carb? and how can i tell if the needle is bad or good?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
