Check eng. Light & Hot
Old May 18, 2008 | 02:53 PM
Bulldogdt's Avatar
Default Check eng. Light & Hot
Has anyone exp. these problem? it wouldn't start, after charging the battery, it runs good, however the check eng. light came on and flashes HOT, went its cold? this is the second time, the first time I took it in and they replace the compacitor, was running okay and after setting for a couple of months, I had to charge the battary and it happen again, any input to what might be cause it?
Old May 18, 2008 | 04:29 PM
sheepdogMSP8117's Avatar
Sounds like maybe the ECM, check with your dealer to see if yours needs to be replaced under the Polaris recall. You'll need the VIN when you call or go there.
Old May 18, 2008 | 07:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yep sheep is right most likely the ecm is bad.
Old May 18, 2008 | 07:55 PM
94harley's Avatar
IF you want to send me your vin via PM and i can run it for you. Keep in mind there is a little personal info involved(name, address, phone number etc) It's up to you.
If I had to bet, I'd say the ecm is toast like the sheepdog said.
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
