2000 scrambler 500
Old May 18, 2008 | 06:14 PM
riptorn's Avatar
Default 2000 scrambler 500
What should the compression reading be for this model, and can you measure it with the decompression relief on the cam???
Old May 18, 2008 | 07:57 PM
94harley's Avatar
I'd have to check at work to verify but I THINK it's like 70lbs compression. If you can get a hold of a cylinder leakage tester use it. Way better check for motors with compression release mechanisms
Old May 18, 2008 | 10:14 PM
Kerbbirds's Avatar
70 - 90 psi for compression, and i agree on the cylinder leakage tester
Old May 18, 2008 | 10:28 PM
riptorn's Avatar
iam geting 30psi right now so i think its time for top end rebuild. do you guys agree???
Thanks for the replys
Old May 18, 2008 | 11:12 PM
94harley's Avatar
I would rather know what the leakage test showed but yes it sounds like overhaul time. I had an old kawi in the shop a week ago and it had 0 compression and 95 percent leakage on the leakage test. It ended up being tight intake valves. Adjusted the cleance and it fired right up. Granted there is damage to the intakes but the cust said leave it. All I'm saying is a compression reading isn't sufficient enough to determine the actual problem.
Old May 20, 2008 | 12:08 PM
MECHANIKE's Avatar
make sure to fully open throttle,+squirt oil in,if reading goes up rings, if not usually valves,like harley said make sure there is not a valve nonclearance problem.
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
