2005 Phoenix will not start
Old May 20, 2008 | 06:54 PM
sbirdzel's Avatar
Default 2005 Phoenix will not start
I have a 2005 Phoenix that is cranking but it will not start. Currently there is no spark. I have verified the spark plug is good as well as the wire (good meaning there is continuity through the wire). I am getting 12 volts through the ignition switch. I don't have a wiring diagram but the kill circuit seems to show an open when the switch is off and closed when the switch is turned on. I am starting to lean towards the CDI box, but I have no way of checking to be sure. Any thoughts out there?
Old May 20, 2008 | 09:48 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Did you check your ETC.....(electronic throttle control),,,,,,caper...........
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
Jun 10, 2015 11:20 PM
hoopduerr
Jun 10, 2015 03:00 PM
1000gade
May 27, 2015 12:37 PM
