Anyone ever heard of tm2 PRE-GRESSOR?
I just came across these for my Polaris and wondering if anyone has used them and do they only make them for the front springs??? Also, will they give lift my wheeler or just used to help with saggy springs!
http://www.atvillustrated.com/?q=node/431
Thanks
Thanks
I saw them on the Polaris accessories website. It fits all Sportsmans up to this years models. http://www.purepolaris.com/Det...463(PolarisPGACatalog) But I don't know anything about them except you can crank it up an inch. That should take all the sag out and make it a little higher. Right?
I bought the rubber coil spring spacers from polaris. I put one on each spring.(front and back) I like the way it rides. I would rather have a tighter ride. They are easy to put in and they do give a little lift. I have heard complaints about them not fitting but mine fit nice and tight. I have had them for 2 years.
<div class="FTQUOTE"><begin quote>Originally posted by: atv gooroo
I bought the rubber coil spring spacers from polaris. I put one on each spring.(front and back) I like the way it rides. I would rather have a tighter ride. They are easy to put in and they do give a little lift. I have heard complaints about them not fitting but mine fit nice and tight. I have had them for 2 years.</end quote></div>
Two years ago, they probuably dont carry them anymore or at least that style!
I don't see why they wouldn't. I have them in the parts book that the lady at the dealer let me have. I saw them on the polaris website not long ago. They make them to help with the sag for when you use a blow. I think they are listed under the blow and accessorie.
http://www.t-m-2.com/tm2/Pregressor/Pregressor.html
go to their sight. they say front and rear. i will be getting a pair for the front of my sp500. after adding a winch my fornt tires look like / \ .
Well I already have a two inch lift on my wheeler, and I wonder by intstalling these, it is going to put my axle in a real bad angle if I crank them all the way up. They say it is only 1 inch of lift.
So is three inches to much on lift without making any major inprovements?
