Top end is limited.. **Update** 6-12-2008 Sound byte added..
87 Trailboss 250 2 stroke
New topend
Kind of hard to explain but if you think about a newer car and there rev limiters. Engine hits a certain RPM and the RPM's go up and down limiting you to go higher. Kind of sounds like this: http://www.youtube.com/watch?v...uFO2FA&feature=related
New topend
yeah i guess it would'nt be good to be held back by the wrong limiter,i tried to get an aftermarket upgrade, no one offers one for this year,not that i need one just did'nt know better,cause i don't think it has one, cause i've been over 65+still accelerating just ran out of room.
Reason I ask is because if you punch the throttle the engine shoots up pretty quick but hits the rev limiter. But I don't think I am going more the 15 mph?? I found out last night that the float is dumping to much fuel into carb. Going to rebuild it. Wondering if the carb fuel/air mixture is the problem. I reset it to stock what manual says and now it will idle. Used to not want to idle. Could to much fuel cause a miss or cause the engine to act like a rev limiter?
Ok all finally got the float needle and seat in. It is not longer dumping fuel from the exhuast pipe. Starts up much easier now. Seems to still have the limiter in the rpm's. Listen to the sound byte and tell me what you think. Does the carb need to be adjusted or what?
http://www.youtube.com/watch?v=7DiWYwCZuUU
exmotocrosser
09-13-2019 06:12 AM
mrtidy
02-03-2016 05:00 PM
Polaris Side by Sides
09-15-2015 03:33 AM
