Water pump still leaking????
Old May 29, 2008 | 10:21 PM
MrSleep's Avatar
Default Water pump still leaking????
OUCH!! I'm not going to go thru THAT much trouble!!! I'll just try silicone and if that doesn't work then let it leak grrr Water isn't THAT expensive! (they couldn't just make a seperate bolt on water pump geezzzz...)
Thanks for all the help!
Old May 30, 2008 | 11:17 AM
TLC's Avatar
TLC
My manual says you have to split the crank to change a oil bump as well.
Water bump or oil bump goes out, you might as well get a new ATV then pay a repair bill like that.
Old Jun 2, 2008 | 11:52 PM
itstillruns's Avatar
I have the Polaris manual< for the oil seal the case has to come apart I have done the watewr seal with out splitting the case I have a 600 to do oil seal and 800 to do water seal in my garage now! should be a better design!
2quiker
Mar 22, 2022 08:36 PM
Minimod
Sep 10, 2015 08:03 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
quickwhips
Sep 2, 2015 06:53 AM
