Xplorer400 clutch issues
Old Jun 1, 2008 | 12:02 AM
Kroy's Avatar
Default Xplorer400 clutch issues
I have a 98 xplorer 400 2 stroke. I used it for turkey hunting last week and in the off time i was doing some driving around and decided to put the throttle down. It took off like a raped ape and then topped out at 30 mph. Couldnt figure out why. I took the clutch cover was off and there was some definate wear on the belt i just put on last summer. I have some oversized tires on it and up until last week never really had any issues with it. Did the clutch finally give out with the size of the tires? Or is there a problem with the reed valve? The carb seems fine. I took it out and cleaned what i could. not really that dirty. After reading some of the past posts, i think its the clutch, but need some more opinions. I am for sure going to put a clutch kit in it with a slightly stiffer spring, but all after i figure out whats going on. Any help or ideas would be helpful. Thanks!!!
Old Jun 1, 2008 | 04:39 AM
user493's Avatar
Moto Psycho
It seems like your big tires are causing the belt to wear out. A clutch kit and new belt should help. You may have other issues too, but it sounds like it's running good, other than no speed.
Old Jun 1, 2008 | 10:05 AM
ftwflh's Avatar
Sounds like the secondary buttons wore out.When you replace them set your spring setting a little lighter to compensate for the bigger tires
Old Jun 2, 2008 | 12:58 PM
Kroy's Avatar
Thanks guys kinda what i was figuring. Anyone have any input on what type of clutch kit to get brand name wise?
Old Jun 2, 2008 | 01:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would do as ftwflh suggested and see how it reacts and adjust from there if need be.
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
