CVT Flushing
Leaf blower works real well for drying equipment also. If you have one you could probably get the majority of the water/moisture out by blowing into the snorkel with the leaf blower.
<div class="FTQUOTE"><begin quote>Originally posted by: MaineWheeler
Sounds like that makes for a nasty mess riding with the coal dust, have you given any though about getting a small air compressor? I spray the **** out of mine with the hose after every ride then use 125psi to blow the moisture out of all the hard to get at places. just a thought</end quote></div>
to me the film that would be left behind would either cause premature belt belt or make the belt slip in some cases. if you have access to an air compressor i would do that and put a dusat cover over the air intake. imo.
