need direction
Old Jun 21, 2008 | 05:49 PM
Default need direction
[img]i/expressions/face-icon-small-happy.gif[/img] Every piston inspite of close tolerances of manufacturing will/can vary!!!! I do not bore untill I have piston in hand to measure bottom of piston skirt ! Any body that does can be off (too small,fine can hone to finish,too BIG cant shrink bore!!
Old Jun 21, 2008 | 07:18 PM
RickRitter's Avatar
I understand completely .
Just curious about where you end up is all . Just wanting to get an idea . Lets say the last one you did --- what was your finish diameter ?
Wiseco has made differences in some of the specs from batch to batch they seem to change tapers and OD's on purpuse on ocassion . I haven't checked the new batch just released ago - not sure of changes . I haven't check the date code on the new ones either .
Always intesting to learn new stuff and different techniques . Thank you !
Old Jun 23, 2008 | 12:13 AM
[img]i/expressions/face-icon-small-happy.gif[/img] Sorry to be late gettin back to ya! I cant,dont,wont,remember final specs! I just measure piston skirt,measure cylinder size,(Iorder piston according to what was in machine /and conditon of cylinder ( If no old piston size known I just measure bore against stock specs,determine what I NEED to clean up bore( 0.25.0.40,etc) I make my first cut about .005 past cylinder bore to start and finish at piston size. Then hone to finish (.001-.0015) clearance. What I end up with I dont remember or write down except on piston box (for customers info) Tired of typing hope this helps!
Old Jun 23, 2008 | 12:19 AM
user493's Avatar
Moto Psycho
<u>Half</u> of a human hair diameter, .002-.003", for clearance. That's <u>close</u>. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Jun 23, 2008 | 12:21 AM
  #15
RickRitter's Avatar
No troubles .
I just find it interesting to talk with other engine builders .
Welcome to the forums again !!
Rick Ritter
Whitelx1
Oct 2, 2015 10:55 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
