driven clutch spring postion
Old Jun 24, 2008 | 10:36 PM
trybaj17's Avatar
Default driven clutch spring postion
i just installed the RCR stage one kit and i love the results so far. what is a good position for the driven clutch? when i took it aprart it was at 2 and 2. i want more power to get to the ground?
Old Jun 24, 2008 | 11:05 PM
[img]i/expressions/face-icon-small-happy.gif[/img] Try 1 on helix, 2 0n bottom, if not what you want,try 1 helix, 3 bottom
Old Jun 24, 2008 | 11:29 PM
ftwflh's Avatar
For all around power with good back shift stay with the 2-2.Go any tighter than that you may not get a full shift out.
Old Jun 25, 2008 | 09:23 PM
trybaj17's Avatar
i am keeping the stocl spring. when i looked at it the spring was already in the 2+2 position. i am just want to get more power to the ground to take advantage of RCR's stage one kit that i haev installed.
Old Jun 25, 2008 | 10:01 PM
ftwflh's Avatar
Call Rick and get you a stiffer secondary spring.I like the Aaen blue for most applications.But Rick will get you either a Dalton or HPD
Old Jun 25, 2008 | 11:09 PM
trybaj17's Avatar
and then should i have it put to the 2+2 setting? or something different to take advantage of the new spring?
Old Jun 25, 2008 | 11:32 PM
ftwflh's Avatar
Start at 2-2 if this doesnt do what you want lighten up the heavier spring to 1-1
I run an EPI pink with a Aaen blue and stock weights on a 03 330 Trailboss and it does great tachs out around 6300 and has tons of midrange pull.
Old Jul 16, 2008 | 06:58 PM
trybaj17's Avatar
how many times should the purple spring from polaris be wound up between the helix and outer casing?
Old Jul 16, 2008 | 07:27 PM
ftwflh's Avatar
1/3 turn counter clockwise.
Old Jul 16, 2008 | 08:16 PM
trybaj17's Avatar
i thought that the spring had a few turns to it? like 1 or 2 complete turns?
