1995 400l Crankcase
Old Jun 25, 2008 | 10:50 PM
catsmandan's Avatar
Default 1995 400l Crankcase
Counterbalancer bearings blew and knock 4 holes in the side where worm gear drives the oil injector pump should i get it welded or find another crankcase side
Old Jun 25, 2008 | 11:32 PM
Depends if you can stop it from leaking fluid (c/balancer cavity only holds about 75-100 cc's oil) Also new counterbalancer? Gear pressed on,bearing not offered by polaris but have had customers MARK gear to c/balancer shaft,press off and find new bearing at local bearing house. Beats price of new c/b! If waterpump end of c/b bad (grooved,rough) bite the bullet because w/pump seals will leak into cavity. If replacing c/b, replace crank gear also! 350 and 400 good engines,but expensive to repair sometimes. Good luck.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wendal
Sep 15, 2015 01:50 PM
KSJOHN
Aug 30, 2015 08:15 AM
