CARB HELP ON A SP500
Old Jul 2, 2008 | 04:13 PM
matt1969's Avatar
Default CARB HELP ON A SP500
i have a 99 sp 500 with a jet kit and it has a stumble.is only has it right at the idle when i give it gas .it doesnat matter where i put the air fuel mixture screw.so i wanted to change the clip postion on the needle.right now im on th forth slot down fom the back.i lve in south fl.thats where the kit said to put it.but if i move the clip will this help with the off idle stumble?if so do i go towards the tip of the needle or towards the back?
Old Jul 2, 2008 | 06:14 PM
NBsportsman's Avatar
If you move the clip up it will lean it out if you move the clip down(toward the point) it will run richer. Try moving it up one notch....
Old Jul 3, 2008 | 01:12 PM
sheepdogMSP8117's Avatar
I agree with moving it up a notch.
A good rule with carb tuning, is to make only one change at a time. If you make two or three adjustments at one time then experience a problem, it will be difficult to know which one caused the problem.
Good luck.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
