Please help. White Smoke
Old Jul 4, 2008 | 08:25 PM
AlwaysBroken's Avatar
Default Please help. White Smoke
I just put an OEM polaris head gasket in my 400 scrambler because it was chugging coolant out the bottle.
Now it's puffing white smoke out the exhaust.
There's no water in the counterbalance. What did I do wrong and where do I go from here? I'm out of ideas.
Thanks
Old Jul 4, 2008 | 08:43 PM
New piston,rings? break-in ? more info needed. Little smoking normal,not a lot, sound like coolant leaking into head gasket, rings
Old Jul 4, 2008 | 09:02 PM
Sorry... about 20 hours on rebuild done in April. Good compression. No visible signs of cracks anywhere. Engine is bone stock except for wiseco piston.
Runs like new, but misting a bit of white smoke. Was not burning coolant prior to gasket, just pressurizing cooling system.
Old head gasket was toast, guy who built the engine used a cheap gasket. I put a Polaris gasket in.
It runs like new and idles perfect. I'm inclined to put it back together and run it to see if it stops, but that's a lot of work for what will probably be nothing.
Should I send the head to Rick? I've tried everything I know but I feel like I'm pissing in the wind.
Thanks
Old Jul 4, 2008 | 09:20 PM
Budman650's Avatar
why did the old head gasket go bad? overheated? warped head? how is the cyclinder base gasket?
Old Jul 4, 2008 | 09:30 PM
Unsure of the base gasket... i didn't think it flowed coolant there so I never pulled it apart that far.
The old gasket went suddenly, not overheated or anything but when I removed it, all the rubber sealer stuff was peeled or peeling. Honestly I don't know why it went.
dirt ryder
Sep 27, 2015 09:22 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
