black wire on CDI help
Old Jul 15, 2008 | 02:22 PM
pwoens's Avatar
Default black wire on CDI help
If I have the black wire from my CDI plugged in my 96 sportsman 500 has a hard time starting and doesnt run correct?? If i unplug it it starts fine and runs great. Does this mean its got a short somewhere?? Is it possible its plugged into the wrong spot??
Is it possible someone could tell me where it needs to be plugged in so I can confirm its not in the wrong plug as I received the ATV and the wire was already unplugged??
thanks
Old Jul 15, 2008 | 03:20 PM
94harley's Avatar
It sounds like maybe the reverse limiter is unplugged rather than the cdi. How many wires are coming off the box that is unplugged?
Old Jul 15, 2008 | 04:17 PM
pwoens's Avatar
just the black wire?? everything else is plugged in.....anything specific I could/should look for to confirm?
thanks
Old Jul 15, 2008 | 04:20 PM
scootergptx's Avatar
Supersock
Hired Gun!
When it's unplugged, do you have to use the reverse over ride button?
Thinking 94harley is right and it's the overide.
Old Jul 15, 2008 | 10:51 PM
Black wire coming DIRECTLY from cdi is kill wire! If runs only with wire disconnected, either left control switch or cdi bad. For me its usually cdi,but dont overlook short in wiring from switch.
Old Jul 16, 2008 | 12:10 AM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: pwoens
thanks</end quote></div>
What colors and how many wires on the box that is unplugged?
Old Jul 16, 2008 | 06:41 PM
pwoens's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 94harley
What colors and how many wires on the box that is unplugged?</end quote></div>
just the black wire from the CDI
Old Jul 16, 2008 | 06:45 PM
pwoens's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: old polaris tech
Black wire coming DIRECTLY from cdi is kill wire! If runs only with wire disconnected, either left control switch or cdi bad. For me its usually cdi,but dont overlook short in wiring from switch.</end quote></div>
yep just the black wire. I pushed the over ride button and it seemed to run better for a few seconds then went back to not running well with the black wire plugged in. I dont think its the over ride ??
Old Jul 16, 2008 | 07:06 PM
94harley's Avatar
just the black wire from the CDI</end quote></div>
I wrote that wrong. What are the colors of the other wires(that are plugged in still) on the box that has the black wire unplugged?
What I' was lookig for is to make sure you are on the cdi and not the limiter box. I believe the limiter has a white, yellow, green and black wire. The cdi has a 3 pin and a two pin connector, a brown wire and I can't remmeber the rest.
Old Oct 8, 2017 | 05:16 PM
Nick Smith's Avatar
question?my black wire from the cdi box got unplugged accidently the kill switch and the key did work but now they don't,where does it hook back up at?
