Polaris 500 HO Oil Change
When I was doing my oil change I followed the book and everything went good until i got to the filter on the oil reserves. It says to remove and clean but I could not get it off...Is it important to clean?? Does it have to been done everytime?? I did the rest of the change and put everything back together..
Its on pretty tight sometimes,un hook hose, use crescent wrench if necessary to turn,once off, just a small screen mesh on fitting to clean. Best to use teflon tape around threads when reinstalling,align outlet with mark on tank. I DONT always remove fitting,just on hard used machines and ones I know that are not serviced reguarly! Most of the time screen will be pretty clean if you do REGULAR maintenance (oil and filter changes at least twice yearly!) Good luck.
Shifts
14
07-13-2015 08:41 AM
