Filled my 08 700 X2 with water
Spent the last 3 days flushing out all the fluids because I filled it with water.
The lesson I learned is a trail can change at anytime. I had just went through this hole 20 minutes earlier in the same spot and the water was up to the floor boards NOT THIS TIME Over the tank the water went and you can guess the rest. One good thing I did find out was just get off as quick as you can and it will float even at 900+ pounds with all my gear on it. With all the new oils and filters it was a costly mistake but i'm ready to ride this weekend.
Did not drive it out...when I looked at the dip stick it was like milk ( NOT GOOD) when we got it out. Towed it to the truck and flushed the crank case and tranz many times with fresh oil and it was dry when the new polaris oil went in. Needless to say the seat is taking more time..
Customer Service #1
May 15, 2020 08:46 AM
jrooker6
Apr 23, 2016 07:36 PM
