Polaris sportsman600 twin !
Old Aug 2, 2008 | 09:09 AM
MicMan24's Avatar
Default Polaris sportsman600 twin !
this may help perhaps... I stopped my atv after a run a nerver had life after. We checked everything, no spark, nothing. the dealership changed a crank shaft censor I believe it was.
Old Aug 2, 2008 | 09:20 AM
700 sportsman's Avatar
OPT would one from a 2004 600 would work too right??
2004 600 stator
Old Aug 2, 2008 | 12:44 PM
Stator changes part numbers on 04 depending on when built. if built before 2/23/03 stators interchange,if 04 built after 2/23/03 then harness different. Be carefull! This is a transition year on 6oo's partly because of coil pack change! Dont just buy off E-bay if one is available unless you are certain of connections and can get a dead on arrival guarantee!!
Old Aug 2, 2008 | 01:28 PM
BlueRubie's Avatar
Found the correct stator for the 03 600 than the guy ended the auction ahead of time now all i can find is the 04+ units.. . ..
I'll keep on digging and keep you guys posted tho i have my doubts it's the problem. . .
Mike D
Old Aug 2, 2008 | 01:32 PM
  #15
polarisman600's Avatar
It is probably the bobbins on the stator. You can replace these yourself. You can buy the bobbins from rickystator.com, for around $40. I had to replace these on my 2000 500 and it saved me hundreds of dollars from getting a new stator from a dealer.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
Jul 7, 2015 11:00 PM
