Front rim question
Old Jul 28, 2008 | 10:12 PM
Koerbs's Avatar
Default Front rim question
This maybe a stupid question but, can you flip a stock steel rim 180 degrees to get more offset?
Its just something that crossed my mind. I wouldn't be doing it, just curious if it can be done.
Old Jul 29, 2008 | 12:30 AM
plumbob's Avatar
Yes,but check the valve stem for clearance on the brake caliper and the strut.I would recommend wheel spacers versus flipping the wheels.
Old Jul 29, 2008 | 12:45 AM
firehog's Avatar
As long as it clears the brake caliper and you may want to drill a new hole for the valve stem. I've seen it done and it seems to work out well for people.
Old Jul 29, 2008 | 04:13 AM
user493's Avatar
Moto Psycho
I did the front and back, just as an experiment. I swapped sides to keep the direction of the tire rotation correct. It looked WEIRD. The back wheels were way out there. I rode it half a mile and switched it back. My front valve stems went tick, tick, tick, as they just barely hit. I think only the caps hit and not the stems.
Old Jul 29, 2008 | 11:18 AM
Koerbs's Avatar
Interesting. What is the offset on a stock front rim?
Old Jul 30, 2008 | 05:23 PM
OIown12's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: firehog
...and you may want to drill a new hole for the valve stem. I've seen it done and it seems to work out well for people.</end quote></div>
What do you do with the old hole!?!?
Old Jul 30, 2008 | 07:36 PM
user493's Avatar
Moto Psycho
<div class="FTQUOTE"><begin quote>Originally posted by: OIown12
What do you do with the old hole!?!?</end quote></div>
I've been wondering that myself. I can think of a few different ways to fill it but none of them seem very good. It would be much better to buy a set of wheel spacers than flip the wheels around IMO.
Old Jul 30, 2008 | 08:19 PM
Koerbs's Avatar
I was just wondering if it can be done, but a stock rim is 7 inches wide and 2+5 offset, if you flipped it, it would be 5+2. So you would stick out 3 more inches on each side, plus a inch more if you had a 10 inch tire, so, you would add 8 inches of width. ICK, it would suck on normal trails.
Old Jul 30, 2008 | 08:32 PM
blaster24's Avatar
You can put an old valve stem in the hole you just put it inside the rim to fill the hole. I have never done it but i seen that done on a yamaha blaster.
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
jettman
Jul 6, 2015 12:16 PM
