Plastic Melting On 08 400HO
Old Jul 29, 2008 | 11:39 PM
RticKwad's Avatar
Runs Stealth!
Default Plastic Melting On 08 400HO
I remember on my former 450 I could feel the heat coming up through the sides of the seat. Hmm were you
running it too long in High when maybe it should of been in LOW (for low speeds or pulling/towing etc.)?
R'
Old Jul 29, 2008 | 11:45 PM
GunnSmoke's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: RticKwad
R'</end quote></div>
does the 400 have low gear??
Old Jul 30, 2008 | 12:53 AM
shank0668's Avatar
i wanna say no
Old Jul 30, 2008 | 07:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
have to check ours. wife it runs wicked hot and cooks her legs if she tries to wear shorts.
Old Jul 30, 2008 | 10:50 AM
  #15
RticKwad's Avatar
Runs Stealth!
Good pt. I did NOT know that it didn't
have low. Okay I will crawl back under
this rock from whence I came, LOL
R'
Old Jul 30, 2008 | 01:42 PM
  #16
00XJ's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
have to check ours. wife it runs wicked hot and cooks her legs if she tries to wear shorts.</end quote></div>
Dittos on that. The Hawkeye will cook your left leg wearing shorts!
Old Jul 30, 2008 | 06:44 PM
  #17
Mongrol's Avatar
"Official Site Skeptic"
I let it idle for 5-10 min in 83 deg temp to check the oil. The heat rising may have caused it.
Old Jul 30, 2008 | 08:34 PM
  #18
Rickeyparker's Avatar
There is alot of heat even on the oil cooled hawkeye. It burns bad tooo
Old Aug 1, 2008 | 05:03 PM
  #19
rigor mortis's Avatar
checked mine last night,didnt see anything on mine,21hrs on it
Old Aug 1, 2008 | 09:33 PM
  #20
jokout's Avatar
Hmmmm..this is strang...I wouldn't expect it to show up there either! I have nothing like this on mine and we have been riding long and hard the last few weekends in 90+ temps...the heat I get off that side it is normally lower radiating off the side of the engine in the clutch area.
I do notice in the pics that the aluminum foil reflective material sits just under this area...not sure if that would be a facture or not...
AND
It does look somewhat similar to damage I have seen caused by a cable shorting out and getting hot...do you have any wiring running through there?
