scrambler 400 Starter Change
Old Aug 4, 2008 | 03:29 PM
kukerdan's Avatar
Default scrambler 400 Starter Change
Hey all..
I need a new started motor, I want to know how to swap it in.
Im assuming I take the recoil off, than what?
I have never done this before
thanks
Old Aug 4, 2008 | 04:28 PM
After you remove recoil,remove two bolts at bottom that hold starter. also opposite end of starter is a bracket that hold starter also. Several ways to remove: Either pull clutch cover and clutches plus backing plate to get access to complete starter bracket and starter,after starter and bracket removal check bendix,grease/replace if bad also. Another method: remove recoil and two bolts, stand on tail end,remove skid plate, remove bracket(back screws hard to get to) and starter. Easier for me to remove skid plate and clutches since I have a lift and clutch tools. Not a good job anyway you do it. Good luck.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
maxjung
Jul 13, 2015 05:11 PM
