Battery indicator blinking
Old Jun 5, 2016 | 07:40 AM
Hornerm's Avatar
Default So I have the same issue on my 04 sportsman 700 twin efi
I have the same issue but I have replaced my voltage regulator and it still does it. I'm not sure if it's the stater/stator or what.
Old Jun 5, 2016 | 08:02 AM
Is it charging 14-14.5 volts at the battery at an idle? If it is have the battery load tested. If it's not charging then it could be stator related. Plus do you know if you have the later model Kokusan or Ducati ignition? Under the front panel you'd have a separate cdi and coil if it's a Kokusan,a combo cd/coil module if you still have the Ducati ignition system that was junk.
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Aug 21, 2015 10:11 PM
Schneider
Jul 24, 2015 05:05 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
