Scrambler 500 help please
ON MY 01 SCRAM 500 RAISING THE NEEDLE THREE GROOVES,#170 MAIN JET,BRITEGREEN EPI PRIMARY SPRING,GOING 2--2 ON THE SECONDARY LIKE FTW+JF SUGGESTED+NOW ITS HARD TO STAY ON THE THING.I SLIDE BACK LIKE THE SEATS ARMORALLED+I WEIGH 230LBS. ITS GOT SOME G'S............
I had an 02 500 4x4 with an FMF Megamax exhaust, k&n filter, ITP wheels and ITP mudlights, and a hotseat clutch kit init. I would have to drag race in 4x4 to keep the front end on the ground. I wil run with much bigger machines, esepially in the woods. Im no small guy 300+ and i was amazed how all the years i road it that i could not kill it. The first year i owned it it was upside down more than on its wheels. I loved this quad but hear are a few of the problems they have. if looking at a used one. Check the ball joints, tierods, swing arm busshings, front and rear sprocket. rear break pads, and the rear axle bushings. Also check the handle bar mounting plate on top of the stearing stem for cracks where they are welded together. I tried doing a ***** won day and riped the bars clean off the shaft. From all the rollovers it had weekend.
To a point.But if you run a open airbox you need the HPD jet kit to compensate for the engine vacum.And you dont need a bigger carb
#15
I didn't know the Generals had any fans. [img]i/expressions/face-icon-small-happy.gif[/img] It's nice to have a homie on the forum, but if you come into my hood wearing red I'll have to shoot you. [img]i/expressions/face-icon-small-smile.gif[/img] West Side rulez. LOL
#17
There aren't many people on here in the middle of the night and I'm on here for several hours straight. I usually read EVERY new post except the nuthouse. Plus I'm a compulsive post ho. [img]i/expressions/face-icon-small-tongue.gif[/img]
#18
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
I didn't know the Generals had any fans. [img][/img] It's nice to have a homie on the forum, but if you come into my hood wearing red I'll have to shoot you. [img][/img] West Side rulez. LOL</end quote></div>
Lol, yeah yeah, bad ownership of a franchise kills fanbase and loyalty. Good things to come in the future for team and city lets hope.
So where do you ride around here, anywhere besides the Mounds?????
#19
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
To a point.But if you run a open airbox you need the HPD jet kit to compensate for the engine vacum.And you dont need a bigger carb</end quote></div>
I thought there was a flatside carb that elemintes vacume, for brtter throttle response.
#20
the TMX flatslide kit is available from AAEN performance its good for about 3 hp, only helps if you change your cam and pipe, so in total you could be looking up to 10 extra hp, that will put your power where the new 450's are at. Are you looking for a 2x4 or 4x4, I have a 2x4 with the above kit, i'm over 300 lbs and still pull wheelies coming out of corners in the twisties. to make the 2x4 wicked off of the line, use a 40 tooth rear sprocket and 12 tooth front, i smoke EVERYBODY off the line, clutching still use stock spring and polaris G weights, can flip it right over from a stand still.
