2000 Trailblazer 250 2 Stroke
Old Aug 19, 2008 | 01:37 PM
kukerdan's Avatar
Default 2000 Trailblazer 250 2 Stroke
if it works, injection system is better, it changes ratio depending on engine rpm
Old Aug 19, 2008 | 01:45 PM
brianvabeach's Avatar
OK, do you think it would be worth the effort to drop this thing by a dealer and have them give it a once over.......or is that just asking for a large bill......[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 19, 2008 | 02:14 PM
ok only one more question for the experts...
if I premix 40:1 ratio. and also fill up the OIL Tank. Lets say the tank / pump works fine......will that not overload the ratio and make this ATV run badly
Old Aug 19, 2008 | 07:58 PM
ftwflh's Avatar
You will need to bleed the oil pump.Unhook the line and run it with premix and watch for drops.
Old Aug 19, 2008 | 09:19 PM
  #15
Budman650's Avatar
I would also use the injector, I agree with ftwflh on the process.
Mixing gas and oil sux unless you have a high perf motor. The 250 uses so little oil you would have to drive for days to see the oil tank level drop, a very long day anyway.
Old Aug 19, 2008 | 11:57 PM
  #16
ok, looks like the pump is located all the way in back of engine. just gonna have to remove plastics to get better look at it I guess and trace lines.
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
