PERFORMANCE
Old Aug 30, 2008 | 03:41 PM
allenduren's Avatar
Default PERFORMANCE
alright i know there is 100's of post but takes forever and cant seem to find right things...
99 polaris scrambler 500ho 4x4... got stock size gator tires on it.. red epi primary clutch spring..
when riding it looses power and dont have nothin after 1/2 probably...and when let off gas it will start backfiring... Loosing gas maybe???
is the carb messed up?? i cleaned while back been that way ever since..
back to performance.......FTWLH i need your smarts again..
will any team roller secondary work like off a 07 08 sportsman 700 or 800??? also what spring you think i should change it back to also what clutch weight you reccomend???
i need to get this running near perfect again... should i get jet kit stage one
thanks all in advance
Old Aug 31, 2008 | 08:07 PM
ftwflh's Avatar
Default PERFORMANCE
Your first thing sounds like a bad air filter or fuel filter.
I havent messed with the Team clutches off of newer Sportsmans I would go for one made for your machine like one from HPD and with the red spring stock weights should be ok.What have you done to the secondary?Take it apart check and change ramp buttons and set the spring to 2-2 from 1-1 setting.
Old Sep 1, 2008 | 04:55 PM
allenduren's Avatar
Default PERFORMANCE
alright how much am i looking at for one them clutchs i just missed brand new one off newer sportsman for 115.. my sec. clutch we set to the highest setting so more resistance or whatever..
and also the fuel filter new. air filter is very old..
Old Sep 1, 2008 | 06:44 PM
ftwflh's Avatar
Default PERFORMANCE
Chane the air filter.
A TEAM roller from HPD or HSP will run in the $280 range with springs and helix.If you go with HPD call Rick Ritter and tell him what you are wanting out of it.And tell him what I told you I was running.
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
