Water Pump Seal Leaking
Old Sep 1, 2008 | 09:18 AM
500H.O.'s Avatar
Default Water Pump Seal Leaking
I noticed coolant leaking out of a weep hole on the bottom of my engine. I have removed the w/p housing and the impeller. How do I remove the seal?
Old Sep 1, 2008 | 12:47 PM
Spdecat's Avatar
You need a special tool to replace the seal without having to remove the engine and split the case . Order from dealer P/N 2872105 and the T handle P/N 2872106
Old Sep 1, 2008 | 01:26 PM
upnort's Avatar
If you bend the shaft that the seal is on the shaft needs to be replaced which involves engine disassembly.
The puller is about 80$'s from Polaris
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Sportsman850
Jul 31, 2015 04:25 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
