2000 Trailblazer 250 2 Stroke
Old Sep 2, 2008 | 11:44 AM
brianvabeach's Avatar
Default 2000 Trailblazer 250 2 Stroke
What type of plug do you suggest for this ATV........also, ATV has been running sluggish in mid throttle range any suggestions.....
How should plug look if properly adjusted carb?? Black/Grey/White......
mine seems to get pretty sooty/black......
Old Sep 2, 2008 | 11:54 AM
ATC250R4ever's Avatar
I like a nice chocolate brown color, lets me know everything is running ok. The sooty black color suggests your machine is running rich, which will rob power, but at the same time make your engine more reliable, as it will never burn up that way. If this is a problem for you, simply adjust your air/fuel mixture to the leaner side.
Old Sep 2, 2008 | 12:09 PM
OK, I am premixing fuel because the injection pump is dead.....so using ratio of 36:1, should I go to 40:1.........only doing the 36:1 because local dealer said it wouldnt hurt since quad is 8 years old.....I just bought it, and not a two stroke guy myself.....
Old Sep 2, 2008 | 11:19 PM
Use 40-1 ratio if premixing. BR8ES plug.
Old Sep 3, 2008 | 07:44 AM
Thanks......
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
