Polaris Parts : Cheaper
Here is some info that anyone w/ a polaris should have.
Sp700 Front wheel bearings BCA 510014
Sp700 Rear drive shaft u-joints NAPA#338
?? Thermal sensor - tells fan when to come on - Wells SW526 less than $30
Sp400&500 Oil Filter STP SMO17
Sp?? Fan www.offroadwarehouse.com
Sp500 Fan p/n 30100515 800-341-7757
sp500 - sp800 oil filter Super Tech ST7317 at Wallmart
Need a front dif rebuild, these parts worked on my 04.5 700.
2 Federal Mogul 108 (output bearing)
2 CR# 15801 (output seals)
1 Federal Mogul 306 (input bearing)
1 Federal Mogul 9748 (input seal)
1 CR Speedi-Sleeve 99098 (for input shaft seal)
1 NTA 815 (needle bearing)
NAPA u-joint(338) works on the inner joint of front stock c.v. axle. (SP700)
Stock CV boot for 02 700: Discount Auto Parts P/N 6-1052 Fits Dodge Neon, not sure what year.
stock cv boot for 03 sp700 car quest part# 85-0904
This is the parts I just used in order to rebuild a rear end on a 2003 Sportsman 600.
Jew your parts dealers for the best prices. I rebuit this one for less than $90.
Beware that if you Penion and Ring gear is bad the best deal I found is $250.00 from Polaris. (Just in case)
2) Bearings - 6010-2RSC3 SRI-2 The brand is KYK
1) Bearing - 6306-2RSC3 SRI-2 The brand is KYK
2) Seals - Polaris PN 3233878
1) Seal - Polaris PN 3233785
1) Bushing - Polaris PN 3233577
1) Qt 90w Gear Oil
These are just some other parts that may help you.
U-joint for 2002 700 sp rear prop shaft - 1-0170 this is a SFK brand
U-joint for 05 700 sp rear prop shaft - 338 this is a Precision brand may be the same a 02 model??
Rear axle bearings for nearly all sportsmans that I'm aware of - 510013 this is a Federal-Mogul Bearing CV Boot kit for the front of 05 model sportsmans - 8409 this is a Precision brand
CV Boot kit for the rear of all 600-800 model sportsmans that I'm aware of - 7427 this is a Precision brand
THE FACTORY POLARIS FAN FROM A 2004 POLARIS SPORTSMAN 400 AND YOU CAN GET IT FROM POLARIS FOR 200 (U.S CURRENCY) OR YOU CAN ORDER IT FROM THE COMPANY THAT MAKES IT FOR 72.00 PLUS SHIPPING. THIS IS THE EXACT FAN. THE PART NUMBER IS SPAL VA07-AP12/C-58A Fan (30100452).HERE IS THE NUMBER TO ORDER IT 800-345-0327, AND THEY MAY HAVE THE OTHER SPORTSMAN FANS ALSO. ENJOY. ""
More stuff, SP500 with the hubs that lock. Front wheel bearings that go inside hub & strut. Timken L44649 & L44643 can be bought at napa or any parts store. I measured the oil seals and call a local bearing supply store. They wanted more for the seals than polaris did.
1) Qt 90w Gear Oil
My '06 500 took 0w-40 but my '08 500 takes 2W-50 according to the owner's manual. I think Polaris is phasing out their 10W-40 and switching to 2W-50 as one common oil for singles and twins. We should know as soon as someone buys an '09 500.
bzdok1234
30
Feb 23, 2016 01:55 PM
