97 Sportsman 500 no batt charge at idle
Old Sep 8, 2008 | 02:03 PM
TheWanderer's Avatar
Default 97 Sportsman 500 no batt charge at idle
Truck will start instantly & run forever if you pull start it, but it seems like it's not charging.
Rev it slightly & the lights will all light up as they should, still no charge.
Charging battery on trickle charger now to begin tests of elec system, anyone have an ideas/pointers to narrow down the search?
Old Sep 8, 2008 | 04:41 PM
02magnum500's Avatar
Gets his share of deer.
if you rev it your lights will brighten more than idle..this is due to the higher voltage when reved up...they dont charge much at idle...should be reading about 13vdc at the battery at idle..(put a volt meter on the battery when it is idling)..shouldnt be more than 15vdc when reved up...make sure the battery is good...replace it if is older than 4 yrs. just my 2 cents...
Old Sep 8, 2008 | 04:49 PM
Good call...never even looked at it...
Went & checked it on the charger;
a)Sticker said 2002
b)There was like zero acid/water in it!
Old Sep 8, 2008 | 05:11 PM
Probably the problem...Get a new battery is what I would do...Yah, if your battery is about 4+ years they seem to go bad. You should be up and running with a new battery.
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
