99 scrambler 400
Old Sep 10, 2008 | 02:41 PM
Nick Danger's Avatar
Default 99 scrambler 400
Porider mentioned piston skirt in a response to karboo.
Is the piston skirt another name for the reed valve, and if so hard tough is it to change out? Would it be something to check out after taking off the carburetor?
Old Sep 10, 2008 | 04:30 PM
BlackRaptor's Avatar
Piston skirt and the reed valve are totally different.
Reed sits between the carb and jug aka the cylinder on a 2 stroke.
Piston skirt is the lower side metal on the piston its self.
Old Sep 11, 2008 | 11:49 AM
Ok, I get it. Later this year, I plan to rebuild the carburetor.
I surmise that I will be close to the reed valve.
Is this something I should go ahead replace while I am down there, or is it something that usually does not have to be replaced?
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
